1994 Toyota Camry Car shakes horribly only @ 50-75 mph- tir
DINGER523
  • 1994 TOYOTA CAMRY
Shakes or Wobbles problem
1994 Toyota Camry 6 cyl Front Wheel Drive Automatic
About a month after getting my front tires replaced with new ones from the Walmart TLE my car started shaking horribly on the bypass only between 50-75mph and then would subside out of that speed range only. I noticed that the car's glove box indicated that the car should have 205 X 65 R15 92V, however the new front ones are 205 X 65 R15 94S. I went back to WM and had them rebalance the tires (before noting this difference) about 2 months later and they figured that would fix it, but it hasn't. Could the last 92 V or 94 S be causing this issue? And now my car leaks oil from being shaken so hard (not tons but there is some on the garage floor after driving: perhaps 3TBPS) because we have regular 20 min/day commutes through these speeds. So could it be an engine issue?
Friday, October 15th, 2010 AT 1:05 AM
MMPRINCE4000
  • 8,548 POSTS
Have the car aligned at a reputable shop. I would also have them balance tires.
Severe shaking can loosen steering and/or suspension components.
The leaking is probably CV axle seals.
Friday, October 15th, 2010 AT 7:14 AM
