1994 Toyota Camry Can't get passenger drive axle out
1994 TOYOTA CAMRY
TTHOMASO
Drive Train Axles Bearings problem
1994 Toyota Camry Front Wheel Drive Automatic
I removed the spring clip and the center bearing bolt but nothing will move from the center bearing to the transaxle.
Dec 29, 2009 at 7:11 AM
  • 31,937 POSTS
HI there,
These can be extremely tight, you are better off removing the support bearing bracket as well and getting the lot out to do on the floor.
Mark (mhpautos)
Dec 29, 2009 at 7:18 AM
DOCFIXIT
  • 18,828 POSTS
Use a pry bar put between transaxle and CV joint pop it out
Dec 29, 2009 at 7:27 AM
