Brakes problem
1994 Toyota Camry V6 Two Wheel Drive Automatic 169000 miles
I pushed my car into the driveway 2 weeks ago. It has what Im calling a broke front driver side axle. It looks like theres a flange or hub connected to the axle and 4 bolts in the hub like the bolts loosened up and pulled out of the engine. My problem is I put the car in neutral and tried to roll it into my garage but the car wont move. I had the emergency brake on for 2 weeks,when I pull the emergency brake release the lever comes up slowly. I tried several times reapplying and releasing and reshifting to neutral. Could it be my emergency brake is stuck on ? If it is how do I free it up or what else should I check ? Thanks much !
Dec 5, 2007 at 9:49 AM
