1994 Toyota Camry brake light on
145,000 MILES • 4 CYL • FWD • AUTOMATIC
RICK66
i need help with my toyota camry.I recently replaced, brake hose on passanger side, and brake light stayed on, even after i bleeded both right and left front wheels.when i unhook the wire that conects to brake fluid container it goes off but as soon as i hook it back on light gos on again.I should mention that the hose i replace came off a 1996 toyota camry wich is a little longer than the origenal one on my car.
Dec 9, 2008 at 12:41 PM
  • 31,937 POSTS
Hi there make sure that the brake fluid level is correct and if that is so the sensor in the master cylinder is faulty. If the sensor is the one in the reservoir, to warn you that the fluid is too low, then you need to replace it or add more brake fluid. Normally that sensor has a floating device built into it, maybe it’s stuck in the down position and a little “wack” might knock it loose.
If the sensor is part of the master cylinder or proportioning valve, the flute valve rod inside it is still tripped. Sometimes that valve cant be reset and you have to buy a new component.
Mark (mhpautos)
Dec 9, 2008 at 1:59 PM
