Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Exterior Light
Brake Light
Fuse
brake light fuse
1994 TOYOTA CAMRY
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
LEO WAXX
MEMBER
1 POST
i want to now which one the brake light fuses.
Oct 15, 2008 at 5:21 PM
Experienced Mechanic
Hi Mr. leo waxx the stoplight fuse is in the fuse block located in no.3 25amp fuse-see below and thank you for using 2carpros
Oct 15, 2008 at 6:39 PM
BONNIE MCCLURE
MEMBER
1 POST
Rear running lights and brake lights not working.
Mar 11, 2021 at 4:09 AM (Merged)
Welcome to 2CarPros.
There is a 20 amp brake light fuse near the left kick panel.
Here are a few links you may find helpful:
I hope this helps. Let me know if you have other questions.
Image (Click to enlarge)
Add image or video
Ask a new question
Engine won't start
Check engine light
