1994 Toyota Camry 5 speed 88,500k miles
1994 TOYOTA CAMRY
MARIP
Leaks oil ONLY when in neutral: was told it might be the rear main seal, but I have my $1200.00 doubts :shock: Any one know for sure what the problem is?: thanks
Mar 2, 2006 at 4:51 PM
FISHERMAN
  • 937 POSTS
where is the oil leak?
Mar 3, 2006 at 1:58 AM
MARIP
It appears to be right under the manifold: I had the valve-cover gasket replaced, but have some doubts on the gasket being seated correctly. It is also getting on the catalytic coverter cover and the oil is burning on it. I have had all the gaskets replaced (except the rear main seal). But am still not sure, could it be residual: meaning from the past oil leaks, and if it is, how long does it take realistically for the oil to burn away? Thanks for your help.
Mar 3, 2006 at 6:46 PM
