1993 Toyota Camry Wagon brake bleeding and Load Sensing Val
1993 TOYOTA CAMRY
21,500 MILES • 6 CYL • FWD • AUTOMATIC
MBRIDGES2
  • 12 POSTS
The brake pedal on my Camry wagon continues to go to the floor with no loss of fluid. Brakes were great until today, when I replaced a short section of line due to rust. This was a rear brake line which runs between a coupler under the rear seat drivers side, and the LPSV (load pressure sensing valve). I replaced one of the two lines, and have bled all four corners AT LEAST A DOZEN TIMES at the bleeders. There are absolutely no fluid leaks. I suspected my master cylinder might have blown seals in the process, so I replaced with a brand new master cylinder. Problem did not change at all. Pedal has spongy pressure but drops to the floor. Car won't stop and is not driveable. Do I have to somehow bleed the LPSV? Is there a unique bleeding procedure with this car? If there is still air in the system somehow, wouldn't I at least have spongy, working brakes? HELP PLEASE!! THANK YOU!!!!!
Oct 12, 2008 at 10:50 AM
Open up the back wheels and inspect the wheel cylinders for leakage -No leakage-try bleeding the system again to inlcude the LPSV. Still no pressure and still sinking its pointing to the new master cylinder leaking internally
Oct 12, 2008 at 12:07 PM
MBRIDGES2
  • 12 POSTS
Thanks very much for the reply...
1)Already checked for caliper and piston leakage. None.
2)Absolutely no drop in reservoir fluid level despite *hundreds* of pedal pushes. Can air leak, but not fluid?
3)How do I bleed the LPSV?
4)When I replaced the master cylinder, I disassembled the old one to inspect the seals. Seals looked perfect and the inside of the cylinder looked pristine. New master cylinder displays identical pedal feel and pressure issue.
Thanks again.
Oct 12, 2008 at 12:39 PM
3)How do I bleed the LPSV? Bleed this one 1st then RR/LR/RF/LF. When you installed the new master cylinder did you bench bleed it?
Oct 12, 2008 at 10:12 PM
MBRIDGES2
  • 12 POSTS
The LSPV cannot be bled because it's completely rotted out. I have bled the all four brakes multiple times in the correct order. I bench bled the master cylinder thoroughly. Brakes are still extremely weak and undriveable. Why can't I bypass the LPSV entirely? I'm desperate. Please keep in mind that my brakes worked great until I replaced a short section of line going into the LSPV. Thanks very much.
Oct 18, 2008 at 6:33 AM
ALFCENTORI
what did you end up doing I am having a leak issue with my LSPV I would like to bypass it
mbridges2 Posted: Sat Oct 18, 2008 10:33 am Post subject:
Dec 15, 2008 at 5:59 AM
