1993 toyota camry V6 100k
1993 TOYOTA CAMRY
ESMERALDA
My car only overheats in slow traffic. Changed the thermostat & radiator. Hoses and gaskets look fine. Dont know a thing about a hydrolic fan but it stays on when I run the a/c. A/C blows ice cold all the time even when I try to adjust it. The reservoir level stays full & bubbles but will empty when I lift the air release valve. The car cools off pretty quickly once I've stopped or speed up again. What could be causing this? ... amy in austin :?:
Jun 11, 2007 at 2:09 AM
[quote:ba34077932="esmeralda"]My car only overheats in slow traffic. Changed the thermostat & radiator. Hoses and gaskets look fine. Dont know a thing about a hydrolic fan but it stays on when I run the a/c. A/C blows ice cold all the time even when I try to adjust it. The reservoir level stays full & bubbles but will empty when I lift the air release valve. The car cools off pretty quickly once I've stopped or speed up again. What could be causing this? ... amy in austin :?:[/quote:ba34077932]
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Pressure test the Rad. cap,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Jun 11, 2007 at 4:37 AM
