Hi there,
When it will not work, check with a test light that you have 12V at the small solenoid wire on the start motor when the key is turned to start, if yes, the problem is in the starter motor if no it will be in the starter circuit, do this test and let me know what you find.
Mark (mhpautos)
SPONSORED LINKS
Thursday, February 25th, 2021 AT 4:12 PM
