1993 Toyota Camry Starting difficulty
JWHOLINE
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 169,500 MILES
My 93 Toyota Camry for the past two weeks has developed a starting problem that happened overnight. This has never been a problem and to happen without any warning has me very frustrated. The problem: when I turn the key all the dash lights come on but that's all that happens. The starter does not engage nor does the engine turn over. My 1st thought was a low battery. So I charged it and tried starting. No change- same problem. Next, I replaced the starter thinking it was a bad solenoid. Still no improvement. So, I had it towed to a Toyota Dealer and all they said it was - was a bad battery. So a new battery was installed. How simple is that. After two days of very cold (below zero) weather I had the same problem. But now I discovered if I turned the key several times it would start on about my 4th attempt. Once the car is warm it starts the first time I turn the key. Now, one more added note; I checked the battery to be sure the voltage was good. It registered 12.73 volts.
When I get it running - it measures 14.9 volts - so I assume I can eliminate the alternator as a problem. The only I can think it can be is the ignition switch. Am I thinking correctly?
Friday, February 15th, 2008 AT 4:26 PM
MASTERTECHTIM
  • 4,749 POSTS
Ignition switch or neutral safety switch. Next time try putting it in neutral to start, if it starts then that is the problem if still no start then replace ignition switch.
Thursday, February 25th, 2021 AT 4:11 PM
