Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Symptoms
Low Power
1993 Toyota Camry sudden loss of power
1993 TOYOTA CAMRY
999,999 MILES • 4 CYL • FWD • AUTOMATIC
BLUPRNT
MEMBER
1 POST
at idle the rpm drops to the point that it almost cuts off
Nov 23, 2008 at 7:30 AM
BMRFIXIT
Experienced Mechanic
check for vacuum leaks and egr operation
remove and clean idle air control valve
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 23, 2008 at 10:09 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
