1993 Toyota Camry Starting in bad weather
BATES40
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • 235,000 MILES
MY 1993 Camry turns over but doesn't start in bad weather (it's currently snowing/sleeting here). I just had the timing belt replaced 6 months ago, and I can smell fuel when the engine turns over. Any ideas?
Wednesday, January 28th, 2009 AT 2:11 PM
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, January 28th, 2009 AT 3:26 PM
