1993 Toyota Camry speedometer
ICECESARIO
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 125,000 MILES
When I give gas the speedometer goes down to zero, when I release the gas pedal it goes up, and starts bouncing around, this happens more on a bumby road how and were should I check for a loose wire, cruise control not working, is it a result from this
Friday, April 16th, 2010 AT 11:05 PM
BMRFIXIT
  • 19,053 POSTS
Check cable out of the tranny and back of the cluster
If doesn't apply check speed sensor but if I recall correctly you should have a cable in it
No speed and no cruise control
Saturday, April 17th, 2010 AT 10:30 PM
ICECESARIO
Im no mechanic but have done my homwork about this car everyone I spoke with said it was the Vehicle speed sensor, but if it was woukldnt the RPM bounce around to and wouldnt the tranny hesitate or not shift right, after I changed the instrument panel clusterand found my problem was still there I disconnected the vss and still found my gauge would still move up and down, telling me that its a voltage short rather then a mechanical problem, I downloaded the electrical diagram and found were all the connectors were, low and behold my problem was located under my glove box it was a loose wire, speedometer and cruise control both work fine nand ow the VSS and Speed cluster were never a problem and there is no cable from dash to vss its all electrical on this 1993 camry LE
Tuesday, April 20th, 2010 AT 8:52 AM
