1993 Toyota Camry need to know where
200,000 MILES • 4 CYL • FWD • AUTOMATIC
BLUE85DUSTY
need to know where ignition coil is on a 1993 toyota camry?
Oct 15, 2010 at 10:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
For the majority of toyota Camry's, the ignition coil is found in the distributor. Typically if you remove the distributor cap, the ignition coil is mounted as the lower portion of the distributor.
If you have a 2VZ-FE, 3VZ-FE, these engines have the coil on the left fender well, near the fuse block.
Oct 15, 2010 at 11:05 AM
