1993 Toyota Camry need to know where
BLUE85DUSTY
  • 1993 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 200,000 MILES
Need to know where ignition coil is on a 1993 toyota camry?
Friday, October 15th, 2010 AT 5:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
For the majority of toyota Camry's, the ignition coil is found in the distributor. Typically if you remove the distributor cap, the ignition coil is mounted as the lower portion of the distributor.
If you have a 2VZ-FE, 3VZ-FE, these engines have the coil on the left fender well, near the fuse block.
Friday, October 15th, 2010 AT 6:05 PM
