1993 Toyota Camry need help
256,785 MILES • 4 CYL • FWD • AUTOMATIC
IAMFOXXY
i need help i bought car 10 miles later it broke down. put gas new fuel pump and ignition coil still wont start
Apr 5, 2010 at 4:57 AM
FREEMBA
  • 1,152 POSTS
I need a little more info in order to try and diagnose your car. Please answer these questions and I'll get back to you.
1. Did you do the work? (need to know if you're mechanically incline, later you might have to run tests yourself)
2. Does it get a spark from the ignition system when you try to crank it?
3. When you spin it over - trying to crank it - does it seem to spin at the normal speed, faster than normal or slower than normal? (very important)
4. What promped you to install the fuel pump?
Also, you might be able to get the person you bought the car from to chip in for the repairs or take the car back under some type of buyers' protection law.
Let me know ASAP.
Apr 7, 2010 at 2:23 AM
