I don't know what else I can do. I have tough time starting after it stalled. car started when cold, but after running few minutes the RPM raise automatically to around 2000 RPM and starts to get rough. Spark plugs have black film, suspect that it's too rich on fuel. timing is checked, spark plugs replaced, spark plug wires, replaced, distributor also replaced (this is the distributor with built in coil), air filter and fuel filter replaced, fuel injectors have been cleaned. What else can I do. Problem is still not fixed yet. After the car is stalled, I would have tough time starting it and while cranking it, I can smell fuel and also something burning. Please help.
Thank you for your time.
William
William
Jan 24, 2009 at 12:39 PM
