1993 Toyota Camry how to change a flash unit
199,000 MILES • 4 CYL • FWD • AUTOMATIC
COCOTHUDA2002
I currently do not have turn signals. i went to the auto store to see what the problem is. I brought the Flasher unit to replace but having a hard time find where the unit is. I, son, dad and uncle have checked under the dash as intruction, but have not been able to locate this. is there a specific place under the dash that i neet look? and what tool do i need to get it out of there?
May 26, 2008 at 3:39 AM
  • 75,988 POSTS
The flasher is with the starter relay in the block relay no.6 above the glove box.
May 26, 2008 at 10:07 AM
COCOTHUDA2002
[quote:1138d33c76="rasmataz"]The flasher is with the starter relay in the block relay no.6 above the glove box.[/quote:1138d33c76]
We have check above the glove box and its not there. i checked under the hood, took the lower panel of the dash off. i have yet to where this is located.
May 27, 2008 at 1:11 AM
KHLOW2008
  • 41,812 POSTS
Did someone remove the unit without your knowing?
Follow Rasmataz advice and see if the mentioned position fits the relay.
May 27, 2008 at 4:42 AM
COCOTHUDA2002
[quote:c062927787="KHLow2008"]Did someone remove the unit without your knowing?
Follow Rasmataz advice and see if the mentioned position fits the relay.[/quote:c062927787]
No there is not place to put this piece above the glove box and yes i did f/u his advice and took the glove box and the under panel off too and there is nothing there. this has become a really big deal hahaha i have taken off the lower panel on the driver side too.
May 27, 2008 at 5:08 AM
KHLOW2008
  • 41,812 POSTS
Right or left shows no results, guess you have also tried centre
Good luck
Our models are right hand drives so maybe tomorrow I will try to see for myself if I can get the location and see if it helps.
May 27, 2008 at 6:12 AM
  • 75,988 POSTS
Look below for the fuse/relay block no.6
https://images.2carpros.com/forum/automotive_pictures/12900_r6_1.jpg
May 27, 2008 at 6:21 AM
