1993 Toyota Camry camry 1993 transmission problem
140,000 MILES • 6 CYL • FWD • AUTOMATIC
CHEWY705
I HAVE A CAMRY 1993 3.0 V6. THE CAR WHEN IT IS COLD AND HAS NOT PUT UP FOR START FORCE, YOU CAN CLICK FULL THROTTLE AND ALMOST NO RUNS. After 10 MINUTES BECAUSE THE CAR IS HOT WORK STARTS NORMAL. THIS TRANSMISSION OIL WELL, I WANT TO KNOW IF THIS PROBLEM IS FOR TRANSMISSION AND THAT THE CAUSE? IN PARKING WELL the engine accelerates. THE PROBLEM IS ONLY WHEN CAR IS COLD. Do I start and have almost no FORCE, ANY SUGGESTIONS?
Dec 30, 2009 at 9:04 PM
KHLOW2008
  • 41,812 POSTS
Hi chewy705,
Thank you for the donation.
Sorry to say this but I am having difficulty undersanding your question.
Do you mean to say when engine is started from cold, it does not rev up when transmission is engaged to D or R and after warming up the problem goes away?
Dec 31, 2009 at 1:02 AM
