Power steering leak
SAMIR2009
  • 1993 TOYOTA CAMRY
I have a leak in the power steering pump.
Thursday, June 25th, 2009 AT 1:54 AM
SQM
  • 6,383 POSTS
Typically, when there is a leak on the pump, it can be either for a leaking hose or the pumps is leaking due to a bad seal.
You will have to inspect to see if you are able to determine where the leak is coming from and replace the faulty item.
Here is a helpful guide:
https://www.2carpros.com/articles/how-to-replace-a-power-steering-pump
Wednesday, November 17th, 2021 AT 9:32 PM
