My rpm is fluctuating up& down and along with that engine is giving jerk. When I took to the mechanic he changed the distributor and for a month it worked good. After that the same problem repeated. Next time I took to a different mechanic and he changed the box which pumps the air into the engine. Even then the problem was not solved. So please tell me what I need to do now.
SPONSORED LINKS
Monday, June 22nd, 2009 AT 7:56 PM
MECHANIC
Hi there,
I would start with having the remainder of the ignition system check, have the firing voltages checked, coil & ignition leads cap & rotor.
