1993 Toyota Camry
TAEISM
  • 1993 TOYOTA CAMRY
1993 Toyota Camry 4 cyl Front Wheel Drive Automatic
trying to pull off the cam shaft pulley.
need to find where to stick the crowbar to stop it from turning.
it said between the engine and the transmission I see a black foam is it under that
Sunday, June 14th, 2009 AT 6:18 AM
  • 31,937 POSTS
Hi there,
you will have to remove the rocker cover and on the cam you will see a square section cast into the cam, hold the cam here with a suitable spanner, remove the torque converter cover plate to access the drive plate to lock the engine if you want to remove the crank shaft front bolt.
Mark (mhpautos)
Sunday, June 14th, 2009 AT 10:54 AM
