Engine Performance problem
1992 Toyota Camry 4 cyl Two Wheel Drive Automatic
the problem happens sussenly once in a while.. after starting my engine it runs good.. after a few hours drive sudddenly when i pump gas the engine goes off as if ther is no fuel in the car.. again when i start the engine the problem goes off.. i chenged fuel pump, sensors, plugs, coil, distributor, fuel filter, chekd injectors,, but still having this rare ptoblem.. also cheked the controller of injectors.. plss help.
Aug 17, 2010 at 10:23 AM
