1992 Toyota Camry 4 cyl Two Wheel Drive Automatic
the problem happens sussenly once in a while. After starting my engine it runs good. After a few hours drive sudddenly when I pump gas the engine goes off as if ther is no fuel in the car. Again when I start the engine the problem goes off. I chenged fuel pump, sensors, plugs, coil, distributor, fuel filter, chekd injectors, but still having this rare ptoblem. Also cheked the controller of injectors. Plss help.
SPONSORED LINKS
Tuesday, August 17th, 2010 AT 5:23 PM
