1992 Toyota Camry tail lights
1992 TOYOTA CAMRY
23,000 MILES • 6 CYL • 2WD • AUTOMATIC
LAHA66
My camry tail lights won't work. I have replaced fuses and the relay. The break lights on the same bulb works, the turn signal work and so do the corner marker(tail) lights. I'm not sure what else to check. I guess thed wireing has to be good because the breaks work. Anything?
Thanks
Feb 10, 2010 at 9:03 AM
Inspect and test the light failure sensor in trunk on left rear quarter panel
Feb 10, 2010 at 10:01 AM
