1992 Toyota Camry Starter
1992 TOYOTA CAMRY
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
1HOWARD
Auto starter will not turn over; no 12 vdc voltage is present at the electrical plug for the starter solenoid; it will not turn over in either park or neutral; I will check the neutral start switch plug tomorrow for corrosion. Can you provide me with a start circuit electrical schematic or tell me what items are in the starting circuit?
Jul 23, 2009 at 3:25 PM
Check the ST main fuse 30amp and starter relay. The starter relay has to ground out in order for the black and red wire on the starter solenoid to have power.
https://images.2carpros.com/forum/automotive_pictures/12900_start_circuit_10.jpg
Jul 23, 2009 at 3:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
see if this helps..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_717.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_187.jpg
Jul 23, 2009 at 3:38 PM
