1992 Toyota Camry speed sensor
GENESTOCKFORD
Electrical problem
1992 Toyota Camry 4 cyl Two Wheel Drive Automatic
where is the speed sensor located on the toyota camry? is it on the transmission or the engine and where exactly?
Dec 26, 2009 at 5:31 AM
BLUELIGHTNIN6
  • 16,542 POSTS
speed sensor #1 (Receiver- Speedometer) is located inside of the speedometer assembly.
speed sensor #1 (sending unit portion) is located on the right side of transaxle case, near right axle shaft inner joint.
speed sensor #2 is on right side of transaxle case.
Mar 5, 2021 at 3:24 AM
