HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Brakes
ABS
Wheel Speed Sensor
Location
SPONSORED LINKS
1992 Toyota Camry speed sensor
GENESTOCKFORD
MEMBER
1992 TOYOTA CAMRY
Electrical problem
1992 Toyota Camry 4 cyl Two Wheel Drive Automatic
where is the speed sensor located on the toyota camry? Is it on the transmission or the engine and where exactly?
Saturday, December 26th, 2009 AT 1:31 PM
BLUELIGHTNIN6
MECHANIC
Speed sensor #1 (Receiver- Speedometer) is located inside of the speedometer assembly.
Speed sensor #1 (sending unit portion) is located on the right side of transaxle case, near right axle shaft inner joint.
Speed sensor #2 is on right side of transaxle case.
SPONSORED LINKS
Friday, March 5th, 2021 AT 11:24 AM
Please
login
or
register
to post a reply.
Related ABS Wheel Speed Sensor Location Content
1998 Toyota Camry Abs Sensors
How Do You Replace Both Rear Abs Sensors?
Asked by
PAUL G 24
1 ANSWER
1998
TOYOTA CAMRY
1997 Toyota Camry Abs Sensor
I Recently Took My Car In To The Shop To Replace A Broken Lug Stud And Patch A Flat Tire. The Car Was Running Great And I Had Never Had Any...
Asked by
chris.cox
1997
TOYOTA CAMRY
Is Abs Necessary For 1996 Toyota Camry
I Just Purchased A 1996 Toyota Camry With 59,990 Miles. It Is A 4 Cylinder Car. When My Mechanic Was Checking It Over, The Abs System Is...
Asked by
dotty
1 ANSWER
1996
TOYOTA CAMRY
1992 Toyota Camry, 190,000mi, V6 3.0l Help!!
Ok, I Had A Blonde Moment The Other Day, And My Driveway Is On A Hill So I Put The Emergency Brake On, Just In Case, And This Morning...
Asked by
Madmax1o12
1992
TOYOTA CAMRY
2004 Toyota Camry Fuel Line Or Brake Line Mount/strap...
One Of The Brackets On The Underside Of The Car Has Come Loose. It Is One Of The Brakets That Mounts The, I Believe Fuel Lines Or Brake...
Asked by
drmoody
2004
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
ABS Module Replacement Video
ABS and Traction Control Module Replacement
Parking Brake Shoe Replacement
Online car repair manuals
