1992 Toyota Camry radiator
PRATHERBOYD
Engine Cooling problem
1992 Toyota Camry 6 cyl Front Wheel Drive Automatic
I replaced the radiator. One of the hoses contted to it leaked a substance and I am trying to figure out what it is.
The substance looks like either oil or transfluid. I tried to upload the picture and could not.
The hose is right behind the fan and runs along the back into a round casing with another hose coming out the other side.
I hope this description helps. I will wait for your reply.
Thank you
Aug 27, 2009 at 10:58 AM
  • 75,988 POSTS
Check the engine oil is it milky if not could be the transmission cooler compartment leaking internally.
Aug 27, 2009 at 11:00 AM
