The problem i'm having is that when I brake the car "surges" to a stop. It feels like the brakes are constantly grabbing and releasing. The pads on the back are new, the pads on the front have plenty of lining left. I had a leaking brake hose on the passenger side front that I replaced and it seems to have gotten worse since being replaced. It was the hose from the master cylinder to the metal hose going to the ABS master cylinder. Also the ABS light randomly comes on. Sometimes it will come on when I start the car and stay on. Other times it doesn't come on at all. I'm assuming the two problems are related. Could it be a bad wheel sensor causing both problems? The rear brakes are a combination of disc and drum. If the shoes are out of adjustment I know that could cause the pulsation but would that cause the Abs light to come on. On a side note the car also shakes violently when at a stop in drive. I doubt that has anything to do with the brake system but just in case. Any help would be appreciated. thank you
Feb 21, 2009 at 10:17 AM
