1992 Toyota Camry Problems, problems......!!!
1992 TOYOTA CAMRY
88,000 MILES • 4 CYL • FWD • AUTOMATIC
JOHNWIN
I purchased my car from my sister who had purchased it from the original owner a few years back. It Had been in a left front collision and was repaired but since we've had it, the transmission is slow. The car runs good, but before takeoff and gear is on drive, the takeoff is slow, no power to move faster. I would usually put it on low gear (L)for it to takeoff and shift to second (S) to feel the gears shifting and from there i can put it on drive (D) and for as long as i'm on the go without stopping the car is okay. What would be causing this problem? Would i need to change to a new transmission which would be very costly. Another "new" problem its having is oil gets into the spark plugs causing the car to jerk and die out. What would be causing this problem and how do i handle this? Am i having some sort of oil leak somewhere? Please help for i am in a bind and in need of transportation.
Jun 4, 2010 at 9:10 PM
Sounds like you have a slipping tranny and for oil in the spark plugs could be valves/rings/cylinder wear
Jun 4, 2010 at 9:19 PM
  • 31,937 POSTS
Hi there, the transmission problem should be check by a qualified-trans specialist, as they will have the special tooling required to check this problem out throughly, as for the oil problem, replace the rocker cover seal and the spark plug tube top seals, also re tighten the spark plug tubes as they do come loose, to do this lock two of the rocker cover nuts on the tube and carefully tighten down using the top nut, if it does not move do not force it.
mark (mhpautos)
Jun 4, 2010 at 9:20 PM
