1992 Toyota Camry Power Windows
TIMOTHY BASS
Electrical problem
1992 Toyota Camry 4 cyl Front Wheel Drive Automatic
My right front power window is not working. I replaced the motor and regulator for the window and it still does not work. Is there a fuse for the power windows and where is it located? I can not find it.
Nov 23, 2008 at 4:05 AM
  • 75,988 POSTS
Get the power window master switch tested out-if its the fuse or main relay to all the switches I don't think the other windows will work-
Nov 23, 2008 at 5:01 AM
