When I bought the car the ABS light was on. Codes said to replace FrontLeft/RearRight ABS wheel speed sensors. I did and codes cleared, ABS light is off. I thought the brake pedal was always a little spongy but after the sensor replacemnt the brake pedal travels nearly to the floor before any braking occurs. (Now the brake pedal might have been that way before the fix but it seems much worse after the fix.) I bled all wheels and found that the FrontRight and RearLeft bleed just fine; but I get no fluid to the FL/RR calibers when I push down on the brake pedal. I removed the FL/RR brake lines from the ABS actuator, fitted them with tubing and was able to get a siphon going to the FL/RR caliper bleed ports using a bottle of brake fluid. By bypassing the ABS actuator I was able to get the FL/RR calipers to drip fluid from their respective bleed ports. Any ideas why I can't bleed FL/RR calipers when their lines are attached to the ABS actuator?
Aug 29, 2008 at 8:05 AM
