1992 Toyota Camry lower control arm replacement
BSEAN9
Steering problem
1992 Toyota Camry Two Wheel Drive Automatic
how do I replace the driver side lower control arm?
Jun 16, 2008 at 12:51 AM
KHLOW2008
  • 41,812 POSTS
Hi bsean9,
1. Remove ball joint, 2 or is it 3 hex nuts.
2. Remove rear bolt, hex bolt from bottom.
3. Remove front bolt, hex bolt from front.
Jun 16, 2008 at 4:51 AM
