1992 Toyota Camry fuel system
212,222 MILES • 6 CYL • FWD • AUTOMATIC
JOESABARA
The car is cranking but not turning over. Is there a fuse that could be blown anywhere other than the regular fuse panel or any thing else before I replace the fuel pump?
Oct 19, 2008 at 11:25 AM
  • 75,988 POSTS
Do you hear the fuel pump come On when you turn key On?
Do below to determine if its fuel or spark problem then comeback
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time/broken or jumped timing belt/chain
Oct 19, 2008 at 12:44 PM
