hi guys ,when i start off in first gear ,the engine shakes and bangs real bad ,but while driving seams ok .THANKS LADS.
Feb 2, 2009 at 8:44 AM
✓Experienced Mechanic
Hi there,
This is called clutch shudder and is a sign of clutch wear and hot spots on the fly wheel, as the clutch is taking up it is slipping a little and causing this vibration, you will need a full clutch o/haul and a flywheel machine to fix this problem.
