My clutch pedal fell to the floor and wont let me shift, before hand the transmission shifted extremely well with no problems
Feb 1, 2008 at 9:43 AM
MASTERTECHTIM
✓Experienced Mechanic
either the linkage fell off the clutch pedal oe the master cylinder for the clutch is leaking. try adding brake fluid to the clutch master cylinder and slowly pump the pedal, it should come back unless there is a huge leak, then you will see brake fluid leaking on the ground. hope this helps
