1992 Toyota Camry
ZAHED
  • 1992 TOYOTA CAMRY
Engine Mechanical problem
1992 Toyota Camry 4 cyl Two Wheel Drive Automatic
my rpm meter is very slow. The rpm reads 1 where it is suposed to read 3 or 4. Pls help me. Where is the rpm swith or sensor? Ist with distributor. Cant find it.
Wednesday, August 18th, 2010 AT 3:07 PM
  • 110,052 POSTS
Are you refering to idle speed?
Thursday, August 19th, 2010 AT 9:45 PM
ZAHED
When I pump the gas the rpm moves a little where it is suppose to move much more. The meter is faulty. Tell me how to fix rpm meter? Or where is the rpm meter sensor or switch?
Thursday, August 19th, 2010 AT 10:03 PM
  • 110,052 POSTS
The communication is done between the gauge and the powertrain control module (PCM). I would recommend having that checked. It is an expensive part and I wouldn't want you to replace it without being 100% sure.
Thursday, August 19th, 2010 AT 10:36 PM
