1992 Toyota Camry
TOM1982
Transmission problem
1992 Toyota Camry 4 cyl Automatic
my friends car started leaking transmission fluid and she asked me to take a look at it. what i say was that fluid is leaking from where the engine and transmission meet. i was curious if a gasket by the flywheel went bad would it constantly pour fluid out as you pour it in. any help would be appreciated.
Apr 17, 2009 at 2:00 PM
BMRFIXIT
  • 19,053 POSTS
Most likely its the front tranny pump seal
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Apr 17, 2009 at 2:26 PM
TOM1982
thank you. hopefully you are right and it can be fixed without too much difficulty. and if there are any other suggestions it would be appreciated. thanks again.
Apr 17, 2009 at 3:07 PM
