I changed the battery and alternator in the car and when i take off the negative cable from the battery the car turns off.why is that?
Dec 6, 2008 at 2:25 PM
✓Experienced Mechanic
The old trick says when you disconnect the battery cable when engine is idling and it dies out it points to the alternator-get the alternator load tested and get back-
