1991 Toyota Camry Starting
GLSSMN2U
Engine Mechanical problem
1991 Toyota Camry 6 cyl Automatic
I was told that the fuel pump needed to be replaced. After replacement, the car still does not start. Turns over but acts as though it is not getting gas. I know that the pump is working because a fuel line cracked when putting the tank back on and when car was turned over the gas came out of break point. After replacing that, still turns over but does not start. Any suggestions what to try next?
Jun 24, 2010 at 3:15 PM
  • 75,988 POSTS
In the air flow meter there's a vane flap,block it wide open and attempt to start-Let me know what happens.
Jun 24, 2010 at 3:44 PM
