1991 Toyota Camry rear washer motor location
1991 TOYOTA CAMRY
24,000 MILES • 6 CYL • 2WD • AUTOMATIC
TBRUCEBOWERS
Where is the pump motor for the rear window washer on a '91 Camry wagon? The front washer motor is attached to the washer resevior, but I can't figure out where the rear washer motor is.
Dec 19, 2008 at 1:34 PM
ZACKMAN
  • 4,202 POSTS
Diagram says right front of engine compartment. It looks like it is attached to the reservoir, as well.
Dec 19, 2008 at 6:15 PM
TBRUCEBOWERS
[quote:87334bae7c="Zackman"]Diagram says right front of engine compartment. It looks like it is attached to the reservoir, as well.[/quote:87334bae7c]
Thanks for the response. I assume that's in the wheel well then. I found a wiring diagram as well that had the general location as right front. Did you actually have a picture with it attached to the reservoir, or is it just near bye?
Dec 20, 2008 at 5:07 AM
ZACKMAN
  • 4,202 POSTS
I am sorry, but I don't have a picture. From experience, both washer pumps are attached to the washer fluid reservoir, either side by side, or one on top of the other.
Dec 20, 2008 at 11:39 AM
TBRUCEBOWERS
Thanks again. I found it. It is attached to the washer reservoir just like the front washer, and is beside it on the tank. Access is accomplished by removing the plastic wheel well shield. Now all I have to do is put all of the interior plastic back that I removed looking for it ;-)
Dec 21, 2008 at 4:43 AM
ZACKMAN
  • 4,202 POSTS
Glad we can be of service. Do come back soon.
Dec 22, 2008 at 1:01 PM
