1991 Toyota Camry power steering hose bolt
175,000 MILES • 4 CYL • 2WD • MANUAL
STEALTHMAN1965
Ok the pressured power steering hose has an eylit kind of part that attatches to the pump by a union bolt I think they call it. THe bolt attatches to the pump. I think I had forgotten to put a washer on the opposite side of bolt so I tried to loosen the bolt but when I did the part that the bolt attatches to broke free. It looks like a wrench can fit on the part that its attatched to. How do I break the bolt and the other part free so I can tighten them both one at a time.
Sep 20, 2010 at 7:20 AM
KHLOW2008
  • 41,812 POSTS
Hi stealthman1965,
You need to slot a wrench onto the pressure port union, ( lower hex joint ) to prevent the hose from twisting and loosen the pressure hose banjo bolt. Due to tight space, it is not going to be easy.
Sep 24, 2010 at 2:23 AM
