1991 Toyota Camry Overdrive
112,000 MILES • 4 CYL • 2WD • AUTOMATIC
CJU67
When I press the button on the gear shift, the overdrive does engage. However when I release the button, it disengages. The only way to use the overdrive is to keep my thumb on the button as I go. Is this a bad switch or a more serious transmission problem? I just got this car, so I'm not sure of its behavior before this.
Thanks
Dec 7, 2009 at 10:44 AM
  • 31,937 POSTS
Hi there, i would be thinking that it is the gear lever switch, this can be checked with a multi meter too see if it is working correctly.
mark (mhpautos)
Dec 7, 2009 at 11:43 AM
