Is there a website that I can go to online to get a manual free?
Oct 18, 2008 at 6:14 AM
✓Experienced Mechanic
What information are you looking for?
Oct 18, 2008 at 6:15 AM
SOUTHERNBEL_2002
MEMBER
Need to find out where my thermostat is and how to flush the radiader
Oct 18, 2008 at 6:17 AM
Follow the bottom radiator hose towards the engine till it meets up to the thermostat housing-its behind it. Radiator flushing- loosen the drain plug and stick a garden hose into the radiator opening and run the water thru it till it clears then close the drain plug add the antifreeze
