1991 Toyota Camry ignition wires
187,000 MILES • 4 CYL • 2WD • AUTOMATIC
CARLOGRASS
While attempting to remove the ignition wires from the spark plugs, one of the wires broke inside the metal tube. I removed the valve cover, hoping to be able to remove the metal tube and the broken wire. Does the metal tube unscrew or is there another way I can remove the wire and sparkplug?
Jun 6, 2008 at 8:21 AM
KHLOW2008
  • 41,812 POSTS
Hi carlograss,
The metal tube is fixed quite tightly and best not to remove if possible.
Try using a metal hook to take out the plug cable parts.
Jun 7, 2008 at 2:09 AM
