what would be the right booster pack to buy for a 35N type battery with 800CCA? I know you would highly recommend me just to have my car repaired but just for the sake of knowing and answering my question.
what is the difference between these:
1) a booster pack with 700 crank assist amp (usually seen at canadian tire, motomaster eliminator brand)
2) a 100/200Amp engine starter (sample. schumacher 2/10/40A, 6/12V charger and 100/200Amp engine starter with battery tester)
will I end up better buying item 1 with 700 crank assist amps or item 2 with 200 amps engine starter?
as for additional information. my main fuse rating is only 150 amps (I can see it connected to the positive terminal of the battery) and I have 35N type battery
Aug 6, 2010 at 12:00 PM
