Did you use a voltmeter to confirm it-If so there's a D-hole behind the alternator-stick an object in there and ground the tap-if voltage increases the internal voltage regulator is defective. If not the alternator
I know its new stuffs but there's such thing as manufacture defects-
Double check all connections from and to the alternator. also at the battery-check all fuses
Mar 9, 2008 at 9:45 AM
