1991 Toyota Camry charging
HURLEY-155
  • 1991 TOYOTA CAMRY
  • 4 CYL
  • FWD
  • 178,000 MILES
I replaced my alternater and my battery and it still wont charge the battery
Sunday, March 9th, 2008 AT 4:35 PM
Did you use a voltmeter to confirm it-If so there's a D-hole behind the alternator-stick an object in there and ground the tap-if voltage increases the internal voltage regulator is defective. If not the alternator
I know its new stuffs but there's such thing as manufacture defects-
Double check all connections from and to the alternator. Also at the battery-check all fuses
Sunday, March 9th, 2008 AT 4:45 PM
HURLEY-155
No I didnt I took the alternater down to the parts house and they tested it and told me it was fine and were are all of the regulaters at?
Sunday, March 9th, 2008 AT 6:42 PM
