1991 Toyota Camry CAR TROUBLE
500,000 MILES • 4 CYL • 2WD • AUTOMATIC
CLINLIN
THERE'S NO POWER. I TRY TO JUMP IT, IT DIDN'T WORK. I BOUGHT A NEW BATTERY, IT DIDN'T WORK TOO. WHAT WOULD IT BE THE PROBLEM?
Jan 19, 2008 at 7:29 AM
MASTERTECHTIM
  • 4,750 POSTS
no power at all. check the 100 amp fuse on the positive battery cable right at the battery, i bet it is no good. feedback and votes are appreciated if i have helped you
Jan 19, 2008 at 7:58 AM
CLINLIN
[quote:2f862b14fb="mastertechtim"]no power at all. check the 100 amp fuse on the positive battery cable right at the battery, i bet it is no good. feedback and votes are appreciated if i have helped you[/quote:2f862b14fb]
thank you, i replace the fuse and the power came up but it wont start. it she does crank but it wont start. what would it be.
Jan 19, 2008 at 11:26 AM
MASTERTECHTIM
  • 4,750 POSTS
well now you have to check for spark, fuel pressure and injector pulse.
Jan 19, 2008 at 12:01 PM
